Snaptop - Snap! Build your own blocks
Snaptop is an Electron wrapper for Snap ! a heavily modified version of Scratch 1.4, ported to JS/HTML.
Note: there is a bug where if you interact with the application, you will be unable to exit.
To install my package of this application, ensure my APT repo is installed first then run:
sudo apt install snaptop
Feel free to remind me when there’s an update announced here:
https://forum.snap.berkeley.edu/t/18162
Update regarding .deb package:
1.0.0-PATCH2 is now uploaded, the launcher should now have an icon!
The file should also be smaller and more downloadable since I used compression and some patience. :happy:
