Android studio is the official IDE for Android, made by Google.
To install my .deb package, install my APT repository, then run the command
sudo apt install android-studio
Note: It is also recommended to install the latest OpenJDK version offered by your distro, such as Debian Testing having openjdk-24-jdk
Warning: There are 32-bit dependencies that Android Studio might need, they are listed here
If the packaged version of Android studio is outdated, just reply with Beep boop
